Old 05-12-2012, 03:13 PM
eddieseve eddieseve is offline
Smile RV-7 Assembly to drill rear spar and flaps
Hi Guys,
A few photos from this weekends efforts, fuse leveled, wings were plugged in, rear spar drilled, flaps hung and trimmed to fit the side of the fuselage, and flap deflection checked.
I am getting a throw of 46 degrees flaps up to down, and was wondering what others had seen.
Hope you enjoy the photos.
https://picasaweb.google.com/1107861...1/RV7Painting#
Cheers
Eddie
Old 05-12-2012, 08:36 PM
GAHco's Avatar
GAHco GAHco is offline
Cool Real nice!
It all looks first class, but I had to take your virtual photo tour from the other side of the world! Thanks for sharing and safely enjoy for many years to come
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 05-25-2012, 05:20 AM
rvindo rvindo is offline
Default main spar for rv 7
guys
I'm starting the wing for rv 7 , but i found the spar that I have is 7-3118 instead of w-706 , does anybody know what 7-3118 spar for ? , did i have the wrong spar in my box , I start to notice that my left nose ribs hole does not match on the 4th and 5th from the tip . any one can help ? thanks
Old 05-25-2012, 05:29 AM
Originally Posted by eddieseve View Post
Hi Guys,
That's exactly what I have on mine.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 05-25-2012, 05:31 AM
Originally Posted by rvindo View Post
guys
That's a number that doesn't appear on the list (at least when I check). Is that coming off the spar itself? Or is that the packing list indicated number? And is this the main spar or the rear spar?
Bob Collins
St. Paul, MN.
Old 05-25-2012, 05:50 AM
Unhappy
I try to look for W-706-L because I want to make left wing first , I started to attached all the ribs just to check , but as I try to cleco the nose ribs I found out that there are two nose ribs did not match the hole , and I found out that the plastic wraped the spar has numbering 7-3118-L , and I started to wonder if vans has send me the wrong spar ? , when you got your spar did it get the W706-L sticker on it ? please assist me
Old 05-25-2012, 09:27 AM
longranger's Avatar
guys
7-3118 is your spar serial number. You will find it on both spars and the center section. If it looks like a spar, it's the right part. Just make sure you figure out which is left and which is right (should be L and R suffix on the serial numbers).
RV-7 TU 904KM (reserved)
Construction Log
Old 05-25-2012, 09:32 AM
longranger's Avatar
I'm at this point myself. The instructions note that there are a couple of nose ribs where the holes in the flange don't all match the holes in the spar, and you have to match drill a new hole in the rib flange using the hole in the spar as a template. You'll also run into this on a couple of inboard main ribs where they attach to the rear spar.
Construction Log
