Old 05-10-2012, 03:38 PM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
Default Climb performance at 8000 ft?
I was talking with a friend who used to own a turbo Cessna 210 (he sold it in anticipation of not being able to renew his medical). He was naturally happy with its climb performance at high-altitude airports. I said I thought that normally-aspirated RVs could climb well at altitude also, and he wanted to know more (he thought I was BSing or overstating the RV performance).
So my question is: what's your climb rate at 8000 feet? VSI rate is fine, and I don't care about standard conditions, etc. If you reply please list:
  • RV model (-4, -6/6A, -7/7A, etc)
  • Engine horsepower (150hp, 160, 180, etc)
  • Climb rate as you best recall at 8000 feet or thereabouts
Ralph Finch
RV-9A QB-SA
Davis, CA
Old 05-10-2012, 04:06 PM
It really depends on weight, temperature, and if you're interested in max climb or cruise climb. My airplane (160 hp RV-6) climbs at about 700 fpm at that altitude and 140 knots on a standard day with just me in the airplane. Loaded for Oshkosh, on a 90+ degree day, the climb isn't nearly as good.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 05-10-2012, 04:24 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
RV10
typical load, warm weather, IAS123knots, typically 800+fpm, and passing through 10,000 700-750fpm.
Approaching FL130 the IAS back to 115knots and still doing 550fpm.
If it were a TN machine I would struggle to keep up!
Old 05-10-2012, 07:37 PM
mtnflyer mtnflyer is offline
Default I love winter in the mtns of Colorado
I fly out of Granby Colo (8000ft elev) in my 6 with an 0-360 and can get almost 2000 ft per minute up to 12000 ft,, but the outside temp will be 0 or below.
In the summer I will get around 12 to 1400 feet per minute climb up to 12000ft. The RVs are the only aircraft to fly in Colorado.
Old 05-10-2012, 08:17 PM
Kevin Horton's Avatar
My flight test data at 8000 ft showed about 1500 ft/mn at Vy at 8000 ft, at my typical gross weight. It would be about 1200 ft/mn at my typical cruise-climb speed.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 05-10-2012, 08:38 PM
N941WR's Avatar
N941WR N941WR is offline
With my 135 HP O-290-D2 RV-9 I could easily cruise climb it at 700 FPM at 10,000' MSL. I was under GW but had 3/4 tanks, my wife and baggage for a weekend away.
The first time I did this I just laughed because many airplanes can't go up that fast at sea level.
I didn't test the new engine at those altitudes but I'm sure it has to be better.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-10-2012, 08:44 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default Just flew this today after reading your post...
Take off at 120 ft elevation and direct climb for 5 minutes to 10,300... pretty light but not on fumes A fairly casual but dedicated climb without close effort to maintain Vy. As I passed 10k the climb rate was solidly above 1,600.
These planes are exceptionally well balanced and truly deserve the tagline - total performance!
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 05-11-2012, 06:33 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
You need two things:
1) Horsepower
2) Constant speed prop.
