Engine Cant or alignment pre-cowling.
I?m getting ready to install a new cowling on a RV-6, 1000TT airframe that I did not build. It is a mid 1990?s slow build kit. Over the years, the engine has sagged and the mount shimmed to keep cowling / spinner spacing correct. As well as new mount isolators. In the interest of doing this job correctly I?m looking for good information on where the engine/prop should be located before I start the new cowl installation. Thinking I should remove all the existing shims/washers to get the engine / mount back to the firewall and standard mounts with no additional washers. I would just like to check if that placement is correct before I do major work based it an assumption. I have searched the forums for this kind of Engine Alignment information and found information that came from Vans saying the engine mount cants the engine 1.25 degrees to the right, assuming for P factor and 0 degrees up and down.
Has anyone ever checked this or adjusted it, if it wasn?t correct? Or if it is really needed to have it ?exactly? on the numbers?
Seems to me with the fuselage leveled both ways, and a few tools like a smart level, it could be checked! Looking for thoughts and information.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
