Old 05-10-2012, 11:36 AM
Flybuddy2's Avatar
Flybuddy2 Flybuddy2 is offline
Default Main Gear Shimmy Video
http://www.youtube.com/watch?v=rzb_e...ature=youtu.be
Old 05-10-2012, 01:10 PM
aarvig's Avatar
aarvig aarvig is offline
Wow! Definitely related to a certain speed range. Do you have any idea what it is?
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 05-10-2012, 01:13 PM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
I saw the vid and saw some kind of stiffener installed. Make sure that the stiffeners are made of WOOD not metal. Also they must be secured with bondo or flox then double spiral wrapped with 2" fiberglas tape whetted with epoxy. Any questions please email me at woodmanrog@comcast.net
Old 05-10-2012, 01:46 PM
Don Patterson's Avatar
Don Patterson Don Patterson is offline
Default Check them tires
I had the same type of problem at 60 hours on Van's stock tires. Put a set of monsters by Dresser on and absolutely no viberation in my 7a.
Old 05-10-2012, 01:53 PM
PerfTech's Avatar
PerfTech PerfTech is offline
Default Shimmy from Mains!!!!!
...If the tires are balanced properly, trued to run with no vertical run-out you don't need any band-aids. One other problem I have seen lately is the use of tire slime to prevent flats (bad idea). If the gear leg starts to vibrate just right, the stuff migrates to one side and snow balls making the problem worse. If the problem persists, let us know and we can help. Allan..
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 05-10-2012, 03:06 PM
Flybuddy2's Avatar
After I switched to Good Year custom IIIs I was having this issue. Tried all kind of things and finally read where a rounder tire (instead of flatter) would eliminate main gear shimmy. Installed Good Year Flight Special IIs and that did the trick.
Old 05-10-2012, 03:14 PM
gasman gasman is offline
And saved a lot of money..................
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 05-10-2012, 03:53 PM
Flybuddy2's Avatar
Thx, but the IIIs had a lot of life left in them. Next door neighbor has same tires on his plane so he got a free gift.
