Old 05-08-2012, 04:19 PM
kinger's Avatar
kinger kinger is offline
Default Is remote ELT switch in the cockpit/panel required?
I did a search and had no luck, not saying it is not previously posted, I just did not find it.
Is a remote ELT switch required in the cockpit for experimental aircraft? If you could provide rule/reference that would be awesome too.
http://members.eaa.org/home/homebuil...e%20items.html
James King
RV-7
919
Old 05-08-2012, 04:32 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
It's a TSO that governs what features the ELT must have, for ELTs installed after a certain date. It's TSO C-91a that specifies a remote switch and visual indicator for the ELT. Applies to both experimental and certificated aircraft
Edit: single-seat airplanes still don't need no steenkin' ELT
Neal Howard
Airplaneless once again...
Old 05-08-2012, 04:59 PM
kinger's Avatar
Neal, THANKS
King
James King
RV-7
919
Old 05-08-2012, 09:14 PM
rzbill's Avatar
rzbill rzbill is offline
Default Not all require remote switch
The NEW EBC 406 ELT is approved under the appropriate TSOs and does not require a remote switch if it is mounted within reach of the pilot.
Bill Pendergrass
ME/AE '82
Old 05-08-2012, 09:16 PM
Neal@F14's Avatar
That's good to know. Since I'll probably have to upgrade the ELT in my new RV-6 to a 406 unit someday too soon.
Neal Howard
