I did two things in an attempt to help alleviate, if not prevent, the "bulging" or pillowing that some report in flight, along the top of the cowling between the fasteners, due to air pressure. We'll see if it works or not
I put a *thick* shin between the firewall/skin flange and the Skybolt receptacle strip...I think it was .050...had a friend cut them to size with a large shear. Then, I laid up fiberglass along the inside aft edge of the cowling, different numbers of strips depending on what was needed where, until the cowling matched the top skin (actually, all the way around), figuring a really good thick fiberglassed aft portion of the cowling would be stiffer and resist the bulging.
We'll see...if I ever get this thing finished (sigh) and flying...
