Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 05-08-2012, 04:58 AM
Don's Avatar
Don Don is offline
Default Aft Mounted Governor?
I am just starting on the FWF part of my RV-9A build. I will be using an RV-200 prop and the Jihostroj P-920-028 Governor (the engine is an IO-340). It's time to drill the holes in the firewall and Drawing 19 has a note for one hole on the upper left part of the firewall that says, "Prop control cable (Aft mounted governor) drill 5/8 dia. Hole".
Before I drill the hole I'd like to verify that the Jihostroj governor is aft mounted and that the hole location shown will work.
Thanks!
Don Alexander
Virginia
RV-9A 257SW Purchase Flying - O-320, Dynon D100
RV-9A 702DA (reserved) Finish Kit IOX-340
www.propjock.com
Old 05-08-2012, 09:25 AM
Lars Lars is offline
It's not the governor that defines the location, it's the engine. It will either mount on the back of the engine, on an adapter on the accessory case, or on the left (pilot's side) front of the engine case. If the governor is aft-mounted, then the hole location shown on the plans will work.
Here's a semi-lousy photo of my Jihostroj governor mounted on the back of my O-360, for reference. Just visible to the right of the battery box.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
