Go Back   VAF Forums > Activity Specific > Aircraft Camping
  #21
Old 06-22-2006, 11:43 AM
the_other_dougreeves the_other_dougreeves is offline
Originally Posted by alpinelakespilot2000
For many years of backpacking I used the MSR Whisperlite stoves and was never pleased with the (lack of) fuel control for simmering. (It's really a bummer after hiking 6-7 miles and climbing 4-5K feet and then have your beef stroganoff all burned and stuck to the bottom of the pan!!!)
The early MSR stoves (e.g., XGK) had two settings - off and on. MSR designed the DragonFly specifically to simmer, and it does work. There are other, new designs that simmer as well, but certainly not all liquid gas stoves will simmer.
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 06-24-2006, 09:23 PM
N941WR's Avatar
N941WR N941WR is offline
I'm a bit late to the party but here is my $.02 worth.
With all the back packing I do in both the winter and summer, at sea level and up to 13,000 + feet I have seen my share of stove failures.
The Pocket Rockets are great but a bit difficult to tell how much fuel is left in the can. One of the hikers I go with weighs each tank before and after every trip. He then writes on it the estimated amount of fuel remaining. Not a big deal in an airplane but packing extra fuel for a week gets old very fast!
The other issue with these stoves is they tend not to work in cold temps. The butane in the can's don't flow well below freezing and may not light. If you are not going to be camping in those types of temps, not a problem.
My preference is a white gas stove. There are number of "good" ones that use pressurized fuel bottles. These work good and my wife has one BUT we never take it backpacking. The reason is my paranoia about equipment failures. On one trip to the Rockies all the stoves experience some type of failure except my Colman.
Stoves such as the Wisperlite have two problems, IMHO. First, it is very easy to leave parts behind or loose them. Second, the hose can be dropped in the dirt and get clogged. Both of those things have happened to hiking buddies of mine.
I have been using one of these Coleman stoves for six years and it has never failed me, even at camps over 13,000 feet.
BTW, here are some pictures of a few of the trips I have had the pleasure of taking. Hope you enjoy them.
PS. One other advantage of using a white gas stove is that you can burn 100 LL in it, in a pinch. If you know what I mean. And lets, hope none of you need to do that!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-25-2006, 04:53 AM
donahuedc donahuedc is offline
Default avgas
I don't know much about camp stoves. But I know that I don't want to eat food cooked with avgas. And I don't want to be in a tent where avgas is being burned. I'm stupid enough without adding lead to my diet.
Old 06-25-2006, 04:52 PM
N941WR's Avatar
You are correct in the lead thing but you will do what you have to if it comes to it.
As for cooking in your tent, I can't think of a better way to kill your self. Never, EVER, cook in your tent!!! If you don't ignite the tent and stuff around it by spilling boiling water on yourself and instinctively standing up, thus knocking the stove over you could die from carbon-monoxide poisoning. As much air that goes through a tent, you think this wouldn't be an issue but people do die from it more frequently than you might imagine.
Bill R.
SC86 - Easley, SC
Old 07-05-2006, 01:53 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Smile Camp Stove
Thanks, guys, for all the replies. I never expected to get so many replies. It's always enlightening to get first hand reports from users rather than the sales pitch from someone wanting to make a buck. I have decided to order the Pocket Rocket as recommended by Doug. At this time, I believe this will satisfy my needs.
Thanks again,
Don Hull
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
