Rear Spar
The rear spar on the RV-9A is a Z section. I dimpled the top and bottom flanges with my pneumatic squeezer, but I'm sure a manual squeezer would work. The rib bottom aft tab with a single rivet hole was dimpled separately.
The rule of thumb, according to the instructions is to dimple up to .040" from memory and machine countersink thicker than that.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
