Old 05-06-2012, 06:18 PM
tx_jayhawk tx_jayhawk is offline
Default Annual Inspection Consumables
All,
Preparing for annual and trying to put together a single order of "consumables" that need replaced. I am thinking about the following:
* Oil
* Filter
* Oil strainer gasket - anybody got a p/n?
* Carb inlet screen gasket - anybody got a p/n?
* Brake pads (if needed)
* ELT batteries (if needed)
* Spark plugs (if needed)
Anything else?
Scott
Old 05-06-2012, 06:26 PM
RV6_flyer's Avatar
Originally Posted by tx_jayhawk View Post
All,
* Oil
* Filter
Anything else?
Scott
Air filter cleaner and oil
Air Filter (if needed)
Wheel bearing grease
Constant Speed prop grease (if equipped)
Spark Plug copper gaskets
Extra hardware (#8 screws, cotter pins, safety wire, etc..)
I am betting that others will add to both of our lists.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 05-06-2012, 06:27 PM
Cotter pins for the axle nuts (What size are those, BTW? I need to order some.)
Safety wire for various things.
#6 and #8 screws to replace boogered up screws.
Star washers for anything that gets pulled apart and uses 'em.
Copper spark plug gaskets.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 05-20-2012, 08:48 PM
walkman's Avatar
walkman walkman is offline
Grease
Brake cleaner/mek/acetone
Intake/exhaust gaskets (I like to have a couple blo proof on hand)
Bag of shop rags
5 gallon bucket
Extra bulb for shop light
Pb blasts/penetrating oil
Intake hoses
Locking tab washer for crarb finger screen
Various size cotter pins ( I have several sizes, wheel, cabin heat muff.....)
Engine degreaser aerosol
Smimple green
Beer
Several aviation monetary units (amu's 1 amu = $1,000 usd)
Hardware (nuts and washers) for exhaust studs
Alternator belt
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 05-20-2012, 09:26 PM
jbDC9 jbDC9 is offline
Oil strainer gasket is a copper crush type, AN900-16, 1" ID. Aircraft Spruce price $.36.
Carb inlet screen gasket is a CF16-A48 gasket with lock tab. ACS p/n is 08-06629, $4.98.
John Bixby
RV-8 QB sn 82030 - 1750 hrs
O-360-A1D/CS/Pmags
Houston, TX
Old 05-20-2012, 11:02 PM
flion's Avatar
flion flion is offline
Plexi cleaner
Torque seal
ELT and remote batteries (if needed)
Oil analysis kit
Not exactly consumable, but I found it handy to get a few AN929 for the fuel system so I could remove the filter and pump with less mess or chance of debris entering the system. Combined with AN815 unions where I needed a plug rather than a cap, they are handy to have.
EAA Technical Counselor #5357
