Old 05-06-2012, 12:20 PM
jimbo jimbo is offline
Default fastener questions from a rookie
1. Is it acceptable to use tinnerman nuts and sheet metal screws to attach adel clamps to let say a subpanel?
http://www.aircraftspruce.com/catalo.../tinnerman.php
2. Are the grasshooper nuts the way to go to attach gauges to the panel?
http://www.aircraftspruce.com/catalo...s/instnuts.php
3. Which method is best-using panel switches with fast-on connectors or screws for ring terminals? Or, put it another way....how hard do the fast-ons separate (after years of use) for fear of yanking out the panel in the process?
Or are these tings Potato Potahto
Thanks for the feedback
Jim
RV9A
working on things electrical
Old 05-06-2012, 01:54 PM
paul mosher
Posts: n/a
Depends on how much you want it to stay on. I only use screws and self locking nuts.
They are acceptable. If you mount the instrument behind the panel get the ones with the legs, they lock into the instrument.
I prefer ring terminals and screws, but sometimes you have no choice.
Old 05-06-2012, 04:59 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
Tinnerman clamp nuts with the correct screw are acceptable in certified planes. The springiness in the teeth that hold the screw provides the self-locking ability.
One easy trick is to use a #8 U-nut on one leg of an Adel clamp. To hold a wire bundle to a flange, only a #19 hole needs to be drilled, no difficult to get at plate nut needs to be riveted in, or difficult to get at self-locking nut to install. Just mount the Adel clamp against the back side of the flange.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-06-2012, 09:29 PM
Gil....Very Nice. That would save time, especially in cramped spaces.
Jim
