06-19-2006, 08:45 PM
Resistive senders with flop tube
I'm having trouble figuring out how the resistive senders get installed in the second bay in my flop tube tank. I see the little drawing that is provided, but is there more info somewhere that I am missing? It gets installed in the rear baffle in the second bay, but where in relation to top/bottom and between the ribs? Anybody have pics or a good reference? Does the float wire get bent 90 degrees?
Thanks for the help in advance!
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
06-19-2006, 08:47 PM
Chief Obfuscation Officer
Rudi
Chad, IIRC Rudi had some good pics he posted here, or maybe on his web site. Maybe he will chime in with a link.
06-19-2006, 08:50 PM
Here's what I was thinking of, but maybe not as many relavant pics as I thought.
http://www.rudigreyling.com/rv_fuel_tanks.html
06-19-2006, 08:56 PM
Thanks Brad!! That is a great link, and really opened my eyes! Now I just need to figure out where it actually goes, dimensionally speaking.
And, using that method, what do you use to seal the rather large hole where T-408 went?
Chad Jensen
06-19-2006, 09:05 PM
T-411
Do you mean the hole for the float sender? I guess you could fab some sort of cover, or you could order a T-411 tank access cover. T-411s come with the capacitvie senders, and are like the T-408 but don't have holes for the sender.
06-19-2006, 09:21 PM
Good call, I'll do that tomorrow.
Chad Jensen
06-19-2006, 09:30 PM
Good timing Chad!
Chad, great timing! I just pulled the site up to see if anyone had posted anything on this and found your question. Looks like I need to order a T-411 also. I don't mind the $5 but disliek the shipping. Maybe I'll just wait and get it with my fuse order.
Thanks for the link Brad and Rudi thanks for the photos!
John Roberts
RV-7A - Fuselage
Williamsburg, Iowa
VAF 393
N624KJ reserved
Numbers 6:24 - The LORD bless thee, and keep thee
06-21-2006, 07:19 PM
Some additional info
I found this post and it appears to have some additional info and photos in it. Worht checking out.
http://www.vansairforce.com/communit...ight=flop+tube
John Roberts
RV-7A - Fuselage
Williamsburg, Iowa
VAF 393
N624KJ reserved
06-21-2006, 08:57 PM
Thanks for that link John. That will help!
Chad Jensen
