Old 05-03-2012, 08:57 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Default iPad usage questions
For those who have iPads do you have the WiFi or WiFi + 4g. Could I make my sprint HTC phone a WiFi hotspot and use that with the new iPad WiFi at altitude?
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 05-03-2012, 09:09 AM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
You should be able to do that however telephone data will only be available sometimes while in flight. It is the same with an iPad with built-in 4G data. That data will be available often on the ground and occasionally in the air. Lower altitudes seem to work better for getting telephone data.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 05-03-2012, 09:13 AM
Rhino889's Avatar
Rhino889 Rhino889 is offline
Above 2000' the 3G signal drops out.
There is a 3G amplifier and booster that others have installed or just plugged into a 12 volt lighter plug. It's designed for auto use in sparse areas.
Reports are that 3G up into the 10,000'+ range.
I found all the info through google.
Booster was about $150 for everything needed. Few months worth of xm subscription
VAF DUES 7/13, 12/13, 03/14
Founder/Director
www.Aircraftwraps.com
This is my personal account and does not reflect the official communications of Aircraftwraps.com. We have retained a username for such correspondence. I post about formation, eating, aerobatics and pilot stuff .
Old 05-03-2012, 09:21 AM
rleffler's Avatar
rleffler rleffler is offline
If you get one w/ 4g, you also get the built in GPS so that you may not need an active data feed if you download all your data before you're airborne. However, that will depend on how your application manages data.
I went this way to eliminate the need for an external GPS. Neither carrier forces you to activate and you can activate for just a month on the new iPads.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 05-03-2012, 09:44 AM
miyu1975's Avatar
ah..so if just had the iPad with GPS and using foreflight I could download my routes and such and then all that is needed to drive that at altitude is the GPS. I guess I thought I would need a cell tower or wifi for this..but it doesn't sound like it. makes sense
Ryan Allen, CFII
E-170/175
Old 05-03-2012, 12:03 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default The wifi plus 3G (or 4G)
is the only way to go --- and only 100 bucks more for the same gigabits -- I have a 64G but, for just flying, 16 is plenty --- 32 is a happy medium if you want to do videos, movies, books, etc.
I have a Dual bluetooth external GPS, but have never had to use it in any RV, Cessna, or Piper I have flown ---- if I end up "permanently" mounting it on the -10 tunnel, I may stick the Dual on the top of the panel.
Old 05-03-2012, 12:14 PM
jbagley's Avatar
jbagley jbagley is offline
Default for me...
One problem I have is the intermittent signal causes the weather radar to come and go on the foreflight map. On a recent local flight I made sure I had the current radar on the map while on the ground; this promptly disappeared shortly after takeoff.
Not a huge deal as it was just a short local flight and I could see where it was raining by looking out the canopy. But, it seems like displaying a radar map a few minutes out date would be better than displaying nothing at all.
Maybe it's a setting somewhere in foreflight...
James Bagley Jr
RV6A flying
RV6 #2 tail done and wings done
Old 05-03-2012, 02:04 PM
MarkW's Avatar
MarkW MarkW is offline
Default iPad
Ryan,
Position is reported from the internal or external GPS. The 3G or 4G comes with the internal GPS which works well. I have to move it closer to the glare shield on occation so it can see the sky and pick up the satelites. That is in a 172 so a RV would be no problem. Internal GPS seems much better than using an external and having to worry about it's battery and signal.
I use mine mostly for flight planning and weather on the ground and filing IFR flight plans and briefings.
All of the sectionals, IFR charts, airport directories and approach charts are all loaded in advance while on the ground and connected to Wi-Fi or 3G.
I loose 3G at about 3000' as others have said but you only loose weather since everything else in preloaded.
This all assumes you are using Foreflight.
Off topic, I noticed you used hinges on your wing tips.
Any comments good or bad, techniques? Would you do it again and if so do you remember which size hinge you used? Width and thickness?
Thanks, looks like you are getting close.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 05-03-2012, 03:52 PM
Steve Melton's Avatar
Default has anyone tried stratus?
http://www.sportys.com/PilotShop/product/17165
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 05-03-2012, 04:25 PM
bret's Avatar
bret bret is offline
I am using the new IPad 4g with Wing X Pro 7 and the AHRS for SV, works very well in the 172. it reads with in 1 NM per hr next to the Garmin 430. and you can simulate a flight on the couch with sectinal chart or google earth.
