I would first measure the torque myself to see if it needs calibration. A friend and I did with our various torque wrenches and found them all good.
Make a simple arrangement of a bar with a bolt on one end and some known weights on the other hanging by a wire. Measure the distance between bolt center and weight attach wire. Then set a few different torque settings and torque on the bolt until the wrench clicks. Compare with your calculation of the known torque. I think we did three settings; low, mid, and high. All came within a few percent of known torque so we figured we were good to go.
Even if your wrench needs adjustment you can find instructions on how to do so online.
Ralph Finch
RV-9A QB-SA
Davis, CA
