Old 06-19-2006, 03:41 PM
TerryPancake TerryPancake is offline
Default What's under your baggage floor?
I am to a point where I can rivet my bagage floor down. Should I wait to put "things" under there? What did you put under there?
Thank you....
Terry W.
RV-7 QB
Emp Done. Fuse and Wings in the Garage.
N825TW reserved
Old 06-19-2006, 04:02 PM
scard's Avatar
scard scard is offline
Since you ask . I have the strobe PS, ELT, and 1/4" sound insulation.
Scott Card
CMW E-Lift
Old 06-19-2006, 04:06 PM
Brian Denk Brian Denk is offline
Jimmy Hoffa.
But seriously folks, I put the strobe power pack immediately behind it, but nothing under it. It's just rudder cables, some wire and dust bunnies.
Brian Denk
RV8 N94BD 425 hrs. SOLD.
'57 C-180 Skywagon aka "Shrek"
RV10 90% completed empecone kit FOR SALE $3k.
Old 06-19-2006, 04:12 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by TerryPancake
I am to a point where I can rivet my bagage floor down. Should I wait to put "things" under there? What did you put under there? Thank you....
I installed the ELT and the "brain box" for the AOA under the baggage floor.
Down the road, I just might fashion another suitable bay below the baggage area intended to be used only occasionally. On long X-country trips I'd like use of that "free" space to stow items such as ropes and tie downs, a spare fuel cap, inner tube, alternator belt, tools, etc. It is likely others already have done just that.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 06-19-2006, 05:14 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Unoriginal contents, maybe original method
I cut a big rectangular hole in the baggage floor behind the passenger and put in some nutplates, made a .063" plate to cover and screw down with low-profile #8 screws. I mounted the strobe PS and the ELT to the underside of the plate. No brackets, nothing on the floor, components come out when you unscrew the plate and flip it over so they are easy to service or replace.
No change in ribs except the nutplates. Beveled the edges of the plate, since they are above the contour of the floor. The wires run into the tunnel and back to the tail quite easily from there.
h
Old 06-19-2006, 05:47 PM
sf3543 sf3543 is offline
Default Under the floor stuff
Under my floor, I have:
AP brain, electric trim relays and roll servo, TXP antenna, Comm antenna, relays for electric flaps, back up battery for the EFIS and a whole lot of wire runs.
Old 06-20-2006, 06:24 AM
Captain_John's Avatar
Anyone got any pics?
CJ
The experiment works!
