Old 04-30-2012, 11:04 AM
flyenforfun's Avatar
flyenforfun flyenforfun is offline
Default Need definite answer on wing bolt torque.
Looking for a final answer on wing bolt torque. I've read many thread and even called vans and the answers are all over the map. Do I use the AN torque values or the NAS bolt values (much higher). So far I have torqued half my 7/16 bolts to the Nas value if 520 to 630 in lbs. the AN value is 450 to 500 I think. Problem?
Which is correct?
Matt Giordano Sr. and Jr.
RV-8 - N861MM
Wilmington, DE
Old 04-30-2012, 11:21 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I'd say that the definitive answer would come from Van's....what did they tell you?
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-30-2012, 11:31 AM
They said they just torque to the AN bolt spec, but they were unaware of the NAS bolt torque values being different
RV-8 - N861MM
Wilmington, DE
Old 04-30-2012, 12:17 PM
Now I fear I have over torqued. Should I back off and retorque to an specs or leave as is.
RV-8 - N861MM
Wilmington, DE
Old 04-30-2012, 12:31 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
If they are NAS bolts leave them alone....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-30-2012, 12:37 PM
They are the NAS Wing bolts torqued to NAS spec of 520 to 630 inch lbs. so torque plus run on torque of the nut I did 600 in lbs, or 50 ft lbs.
Why do I feel like I am the only builder in the world who does some of the things I do. Someone always knows something I don't.
RV-8 - N861MM
Wilmington, DE
Old 04-30-2012, 12:45 PM
DGlaeser DGlaeser is offline
'cause you weren't hanging around my shop when I felt that way
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 04-30-2012, 01:07 PM
Well now I feel a little better.
What are your wing bolts torqued to?
RV-8 - N861MM
Wilmington, DE
Old 04-30-2012, 02:30 PM
longranger's Avatar
Am I correct in thinking that these bolts are loaded almost exclusively in shear, so the torque might not be as critical as it would be for a bolt in tension (like a connecting rod bolt), thus Van's recommendation that standard AN torque is adequate?
RV-7 TU 904KM (reserved)
Construction Log
Old 04-30-2012, 04:39 PM
Tell me this, torquing experts. Those of you who torqued any bolts from the head, did you incorporate the torque it takes to turn the bolt in the hole? I just measured 25 ft lbs to just turn the bolt in the hole, no nut. Does this mean when vans told me to torque to 40 ft lbs, head or nut, I am under torquing by 25 ft lbs?
RV-8 - N861MM
Wilmington, DE
