Thanks Paul
I will reconsider the placement regarding maintenance access. However I do not expect much maintenace with the sensors, but I might be wrong. I was more afraid of radiating heat from the exhausts.
Thats roughly how the FWF layout looks like:
The top left part of the firewall is taken by the Christen inverted system. And most of the left side is obstructed by the oil cooler and oil lines. I would like to have the centre part as open as possible for oil filter change.
As you may notice, I plan to have the restriction for the fuel pressure sensor in the T piece placed after fuel flow sensor.
No worries, the black & green garden hose is only for trial reasons, it will be replaced by a proper hose. Teh air box for cabin heat is not yet placed.
