Hi Brice-
Put an aluminum doubler on the aft side of the firewall wherever you want a pass through with a bushing. Shouldn't have any problem if you do that. FWIW, I only used the double bushing methods for the control cables where a little bit of flex helped with routing (and where you needed to split the bushings to fit over the cables). For wires I used the single smallest bushing I could, unsplit, to hold any wires tight so that there would not be any relative movement between wires, bushings, firewall holes and their associated doublers. Used CS1900 over everything topped off by stainless steel grommet shields.
Not a full answer to your specific question, but hope it helps.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
