Old 04-29-2012, 09:35 PM
Steve Melton's Avatar
Default I'm sure there is a better way
I was able to drill a hole for a -7 snap bushing the in the aft side of the center push rod tunnel (floors riveted) with a unibit step drill using a small hand ratchet and a socket to rotate the unibit. Space is limited. I did it making 70 degree motions. I'm glad I only need one hole. It probably took 30 min but felt like 2 hrs. Is there a better way?
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 04-29-2012, 09:55 PM
John Courte John Courte is offline
Depends on the size of your unibit shank. If it's 1/4" (or 3/16?) like on some of the smaller unibits (1/2" max), you can chuck it into a right-angle die grinder.
That gets dicey because die grinders are not known for their controllability or precision when used this way. All I know is that it worked for me once: I used this method to drill the holes for something (can't remember what it was), only with a 1/4" drill bit.
A slightly more intense, but probably better, method would be to take your unibit to the local machine shop and have them lathe and thread the shank so it will screw into a 90-degree angle drill. I could see a few uses for that in various places.
RV-7 N313TD
SOLD 7/2/2020
Old 04-30-2012, 06:12 AM
131RB 131RB is offline
Try one of these.
http://www.aircraft-tool.com/shop/de...RODUCT_ID=A604
This chuck will thread into your angle drill and you can install your unibit with a quarter inch shank in it. It will also hold anything with a smaller shank. Very handy in tight quarters.
Ryan
Old 04-30-2012, 07:00 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
The Unibit in a die grinder works well. Just drill a pilot hole with an angles drill first. Control the die grinder by running it at a reduced pressure. The Harbor Freight mini one works well -
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-30-2012, 07:30 AM
krw5927 krw5927 is offline
Harbor Freight has inexpensive unibits with 1/4" hex shanks, and your local home improvement store carries a right-angle drill adapter for around $20 that accepts hex shanks.
http://www.lowes.com/pd_132-41401-13...ductId=3011804
With this combination I've been able to make bushing holes everywhere I've needed them so far.
Kurt W.
RV9A
FLYING!!!
Old 04-30-2012, 10:15 AM
Default thanks for the help
thanks for the advice. there is a better way. my backside thanks you.
Steve Melton
Cincinnati, OH
