Figured that this would be a good time to see how well the ailerons fit the wing. It's a good time because I haven't started the flaps yet, except for roughing out the stiffeners, and some builders have reported that the flap trailing edge extends aft of where the aileron trailing edge would like to be, without some massaging to make them line up.
I plotted out the dimensions from Dwg 4 on a slab of nice plywood to make the wing template cut-out. The manual says that a paper template is provided, and if it's not, then the outline is drawn on the lid of the wing kit. Of course, neither were supplied with the kit. I got to use a spline and ducks, or I would have if I'd had any ducks. But I didn't. Ducks, in case you didn't know, are real tools. Well, yeah, they're also birds.
Here's an article about making your own. Me, I just spotted some weights around and they did the trick. I drew the actual airfoil curve and an outline 1/4 inch fatter than that all around, to allow for carpet.
Since this is an RV-3B and the builder MUST be suspicious, I went and bought a piece of posterboard and made an outline of the actual wing. I used the left tip and cross-checked it to the right tip. Here are the nose and main sections of the posterboard template. If you look closely you can see that they don't match the drawn lines at all.
Also they don't have centerlines.
I used the tooling holes in the wing ribs to determine the centerline positions. Should have done this before I assembled the wing!
Once I got things lined up and checked it didn't look all that bad.
Here's a picture from the plans showing how the fit is supposed to be. The aileron spar should be 3.75 inches aft of the wing's rear spar, and the aileron, trailing edge to spar, should be 9.25 inches - and that's okay.
I drew out a template on the posterboard for the aileron and it matches the actual ailerons nicely. Unfortunately there's an issue: The wing skins are too far apart for the aileron to fair properly. Look closely at this picture:
The aileron spar is located the proper distance aft of the wing's rear spar. The aileron and wing centerlines are lined up. The aileron trailing edge is .40 inches aft of where it should be, but that's not a serious issue. Look at the top skin (The wing section is shown upside down so it's on the bottom) and the bottom skin (shown on top). They sure don't line up with the aileron, do they?
There's the problem.
Dave
