Old 04-26-2012, 06:12 PM
mikehoover's Avatar
mikehoover mikehoover is offline
Default Special tool for removing inner plug in engine?
Lycoming advised me to puncture or remove the inner plug in my O-320 that has the hollow crank since I am using a fixed pitch prop. After puncuting it a few times I decided it might be better to just remove it. It is not budging. Is there a special tool or method required? Thanks!
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 04-26-2012, 06:25 PM
rv6rick's Avatar
rv6rick rv6rick is offline
JOAT-MON & Moderator
I use a dent puller as in the body shop method. Put some grease in there to catch any little drilling flecks, then drill a small hole (1/8" or so). Screw in the dent puller and give it one good whack one the slide.
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
BRONZE / SILVER & GOLD LINDY AWARD WINNING RV's & Rockets
EAA Oshkosh Homebuilt Judge/Tech Counselor/Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox/RV4/6/7/8/9/10/12/14?s
6 RV10's
2 Time Sun n Fun Grand Champion
F1 Rocket #1 Oshkosh Gold Lindy Grand Champion!
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
53 RV's & Rockets & counting
Whirlwind Prop Dealer
Love my Pitts S-1S
Old 04-26-2012, 06:36 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
I'm curious why you want to remove it. I had a small oil leak at my ring gear, pulled the front plug and found the rear was intact. I punctured a small, 1/8" square hole in it, and have had not further issues in another 50 hours of operation....
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 04-26-2012, 07:22 PM
N941WR's Avatar
N941WR N941WR is offline
Don't remove it, you will be fine.
On both of my engines I took a long Phillips screwdriver and punch two holes in that seal before pounding the outer seal in place.
The guys who get in trouble are the ones who don't punch a hole in it.
Also, be careful, if you use a dent puller and have the cross tube in the crank. You could damage it.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
