Old 04-26-2012, 08:09 AM
AJ85WA's Avatar
AJ85WA AJ85WA is offline
Default IO-360 cracked case
Hi guys.
Its really hard to find a good engine for my RV here in Oz. But I have now discover a local one for sale, good compression with 1000 HTR but it has a crack in the crank case leaking oil.
How much work is involved to get this repaired and what ballpark figure would I be looking at for a repair?
Thanks AJ
AJ Wessels (Perth Australia)
Completed - RV6
http://rv6aj.wordpress.com/
Old 04-26-2012, 10:23 AM
drakerv drakerv is offline
Contact Divco aviation. Oklahoma Usa
Old 04-26-2012, 11:50 AM
pierre smith's Avatar
Default Depends.
AJ, it depends where the crack is. Some are not repairable due to their location, so be sure that the seller understands that he'd have to guarantee the case to be repairable or absorb the cost of a good used one or a new one if you can't find a used one.
Surely there are places in Oz that can do the work.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-26-2012, 03:00 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
If you are trying to save money, give Greg a call at Suncoast Aero, he often has engines which they overhaul and zero time, might save you a few bucks.
Otherwise for the less trouble option, XIO360 from Vans.
Old 04-26-2012, 03:11 PM
loopfuzz's Avatar
loopfuzz loopfuzz is offline
If I remember right it cost around $800 for my IO-360 case to be inspected and repaired. It had a crack.
RV6
Maule M5
