Old 04-24-2012, 02:49 PM
ron sterba ron sterba is offline
Cool Dynon Roll Servo Install.
Hi Guys. Hooking up Dynon wing servo and I found out one twisted pair needs 6-8 twists per foot and here's my Question. At the servo did you use spade connectors or Molex connector to the wiring harness at the servo?
QBRV9A
Ron in Oregon
Old 04-24-2012, 04:25 PM
airguy's Avatar
airguy airguy is offline
DB9 connectors.
Old 04-24-2012, 04:39 PM
BillC BillC is offline
I used a Molex connector and no problems in over 2 years of use.
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
Old 04-24-2012, 04:48 PM
Brantel's Avatar
Brantel Brantel is offline
I used a 9 pin D shell type connector.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-24-2012, 07:12 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Pins Only
I figure the servo is not coming in and out so I just used the DB9 pins and used heat shrink tube over each connection the one large piece over the entire bundle. If I ever have to remove it, i just cut away the heat shrink tube.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 04-25-2012, 04:10 PM
Ok Guys I got it. Looks like all will do the job just fine. I'll have to see whats for sale locally. Appreciate your ideas.
Ron in Oregon
