Old 04-23-2012, 08:35 PM
buz buz is offline
Default Control cables outer cover melted
I was changing the oil today and noticed the cluster of control cables for the throttle, mixture, prop had there green plastic outer cover melted off in places just a few inches foreward of the firewall. After a closer look for the source of heat, it appears that the outlet from the heat muffs were the culprit. I am in Florida and rarely use heat, so the heat is continuously bypassing at the firewall diverter valve and blowing on the cables.
Could I just block off the inlet air to the muffs in the summer or would the muffs get too hot without flow through them. I'm thinking it will be fine but thought I would ask for opinions first.
Jamie Busby
AT-502B
RV-6 Sold
RV-10
Old 04-23-2012, 10:05 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I spoke with Vettermen about this and he told me to either let air flow thru the muffs, or remove the muffs and install a heat shield
Bill Peyton
RV-10 - 1285 hours
N37CP
First Flight Oct 2012
Aviation Partners, LLC
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Old 04-23-2012, 11:22 PM
Strasnuts Strasnuts is offline
One of my cables (I believe prop gov.) had bubbles in the green sheathing near the exhaust. I wrapped in it silicone tape and it seems fine after 200 hours.
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
Old 04-24-2012, 04:27 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Ours are all like that too.
600+ hours.......... no problem
Old 04-24-2012, 04:43 AM
rleffler's Avatar
rleffler rleffler is offline
While it doesn't help you, for those still building, Cablecraft does sell a version with a black sleeve that is rated about 80 degrees higher than the green sleeve.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 04-24-2012, 05:03 AM
Default I dump the heated air overboard when not needed
It seemed logical to me that it was not a good idea to dump heated air into the area between the engine and the firewall so I routed a hose/tube to the cooling air outlet when I configured the heater/defroster system.
Bob Axsom
Old 04-24-2012, 05:34 AM
buz buz is offline
Oz,
You say yours are like that. Like what?
Melted cables or blocked off muffs?
Jamie Busby
AT-502B
RV-6 Sold
RV-10
Old 04-24-2012, 06:52 AM
Phil's Avatar
Phil Phil is offline
What is the rating on the Van's green sleeve cables?
Phil
Old 04-24-2012, 06:54 AM
RV10inOz's Avatar
melted green stuff.......
And under the sump.....Nowhere near the exhaust either!
Old 04-24-2012, 07:26 AM
Walt's Avatar
Walt Walt is offline
I always install firesleeve on exposed areas of cable FWF to help prevent heat damage.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
