Old 04-23-2012, 07:05 PM
carrollcw's Avatar
carrollcw carrollcw is offline
Default How long should the bending brake be?
So, I am about to bend the trailing edge of the elevator on my -7. The elevator is approx 3.5 feet, so I need a 4 foot brake to bend them. However, will I need the brake for anything else? If so, will I need the brake to be greater than 4 feet?
RV-7 Flying Since March 2015
N412HC
Titan IOX-370
SDS Tunable Injectors
EFII Dual Ignition and Fuel Injection
Garmin G3X Touch
Whirl Wind 200RV Prop
7XS0 Polly Ranch Airpark, Friendswood, TX
Old 04-23-2012, 07:49 PM
jarvis jarvis is offline
Ailerons are 52" long--you'll need it for them. However, with the quality of today's lumber, if your don't screw it, clamp it, and set a building on it--it'll be so warped by the time you get to the ailerons, you'll want to make a new one anyway.
My $.02--worth what you paid.
Jarvis
Purchased flying RV-7A
RV-7A emp finished, wings next.
Old 04-23-2012, 08:30 PM
carrollcw's Avatar
Is everyone using a joiner, or are they using the 2x8's as is if they are pretty straight?
N412HC
Titan IOX-370
Garmin G3X Touch
Old 04-23-2012, 09:10 PM
DaAV8R DaAV8R is offline
Default I did
I used a joiner to true things up and used the 1 1/2" edge for the bending face. Worked for me.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 04-23-2012, 10:58 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Since you've got QB ailerons, I can't think of anything else you'll need it for but the elevators Clark - I seem to recall just cutting an 8' 2x8 in half when I did that years ago.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-24-2012, 09:03 AM
longranger's Avatar
Amen to that! using the 1-1/2" edge gives the brake a LOT of rigidity along it's length; that's why floor and ceiling joists (and spars) are set on edge instead of being laid flat. The borrowed one I'm using now is about 5 feet long and was built by a retired finish carpenter, I'm guessing 8-10 years ago and it's still "straght as a board". (Sorry couldn't resist). When it's closes you can't even see the working edges; it looks like a single board. Using bar clamps for leverage, you actually have to be careful to not overbend, whereas my old one built per plans was just barely adequate to do the job.
Ready to bend:
About a minute later (most of which entailed installing the bar clamps):
RV-7 TU 904KM (reserved)
Construction Log
