Old 04-23-2012, 04:59 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default Panel rebuild
Back in the air!! One step closer to making her all the plane I want her to be!!
Before:
After:
Thanks to Bill at Up North Aviation for a fantastic CNC cut panel, and Matt at Aircraft Engravers for perfect placards!!
Johnson Creek, here I come!!
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 04-23-2012, 05:14 PM
SmilingJack's Avatar
Very Nice Job Chris!
Now you just need to get some airspeed and Altitude on that thing!
John Mastro
RV-8 (SOLD)
10 years of Awesomeness!
Old 04-24-2012, 09:33 PM
jacknife jacknife is offline
Default Change yer balls y'all
Great vfr panel but tradition has the black ball on the throttle and the blue one on the prop governor.
Cheers, Ralph
Old 04-25-2012, 05:46 AM
ccsmith51's Avatar
Cheers, Ralph
Thanks for the compliments, John & Ralph.
The black ball is the throttle, the red is mixture, and the blue is elevator trim. I have seen quite a few trim levers with blue balls, but if there is a better color in this particular arrangement, I'm open to changing it. Any suggestions would be appreciated.
Chris Smith
Old 04-25-2012, 10:01 AM
n38139 n38139 is offline
Default Extended RV-4 panel
Here is a photo of a panel I put in a RV-4 and I believe I extended it about 1.5 inches. I thought I knew how to put in an image but I guess I don't, here is the address.
http://imageshack.us/photo/my-images/525/dsc01435e.jpg/
Old 04-25-2012, 08:20 PM
dealfair dealfair is offline
Default SWEET!
You can go anywhere you want with that. I love -4s for x-country. Good work!
ENJOY!!
Deal Fair
RV-4 (N34CB)
George West, TX (8T6)
Old 04-29-2012, 05:26 PM
Default Ah, you got me!!
Sure, that makes sense. But still, I would be tempted to either put a different shape on the knob to give it a distinctive feel. Or do like I've seen Tom Martin do. He kept the lever flat (i.e. didn't jog the top to mount the ball) and just slab sided it with a couple of very thin pieces of polished rosewood and then riveted through all three.
I like your panel and the way you have mounted the important stuff as close to the top as you can. Since I've started back flying I can't believe how busy the low level airspace is. I want my head up and my eyes looking out side. A quick glance down is all you can afford. Yours works for me. Enjoy your ride.
Ralph
C-FGWW
