Old 04-22-2012, 08:00 PM
JackW JackW is offline
Default RV-6A First Flight
G'day all,
Certificate of Airworthiness issued 10:30 21Apr12 and reporting first flight of VH-VNS RV6A kit 20938 10:31am 22Apr12 Australian EST from Mangalore (YMNG) airport in Central Victoria. Flight duration was 20 minutes. None of the wings were heavier than any of the others although right rudder was required to keep the ball centered. Only problem was with the pitch trim control which is via the VP-X computer; configuration dropped out leaving the pitch trim uncontrolled (but in trail). Probably need to get to the root cause of that one.
Engine is an IO-320 fully rebuilt with dual Lightspeed Plasma II+ ignition. With test prop on, engine exceeds 2700rpm so producing a little more than the standard 160hp. Prop is a Sensenich FP. Fatso is probably one of the heavier RV6A's at 480kg (1058lbs) Basic empty weight
Some photos will be forthcoming.
Grin now installed on face, see some of you at Oshkosh this year.
John Bridges
RV6A - Finally in the air
Melbourne, Australia.
John Bridges
Riddells Creek (YRID)
near Melbourne, Oz
VH-VNS, RV-6A, IO-320
It flies!
Old 04-22-2012, 09:04 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Congratulations! Very few people have done what you have accomplished - you should be very proud!
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 04-22-2012, 09:44 PM
Default And the very best model by the way
I am perhaps a little prejudiced. Ours was 1201 lbs - slim. Hey Brad what happened in January 1964 and who is "L"?
Bob Axsom
Old 04-22-2012, 11:09 PM
Default Scales
Took me three sets of scales before I got a result I liked...
John Bridges
near Melbourne, Oz
It flies!
Old 04-22-2012, 11:33 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Congrats!!!!!!!!!!!!
Congratulations on your fledge
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-22-2012, 11:34 PM
gasman gasman is offline
John, be sure to drop a note to Van's so he can add your 6A to the completed list.
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Old 04-23-2012, 05:00 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Well done!
Welcome to the Aussie Retard Vehicle club.....affectionately said
Hey let 20lbs out of each tyre will reduce your weight by 40lbs
Make sure you bring it to Ausfly in September, 13-16. YNRM Narromine NSW. Keep n eye on www.ausfly.com.au for details in the coming weeks
Old 04-23-2012, 05:09 AM
rzbill's Avatar
rzbill rzbill is offline
YAY! Congratulations!
What a great feeling eh?
Bill Pendergrass
ME/AE '82
Old 04-23-2012, 07:17 AM
ChiefPilot's Avatar
Bob Axsom
"One Six for Brad & Lynn" :-)
Old 04-23-2012, 10:21 AM
WingsOnWheels WingsOnWheels is online now
Congrats on the first flight!!! I hope to do the same with my 6A eventually.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
