04-19-2012, 11:08 PM
Spar Nick...fixable?
I started my wings today. I pulled out the spars and started to examine them closely. My left spar is perfect. The right on the other hand had a few scratches, but they are superficial. The one spot that leaves me worried is this one on the bottom bend near the end of the beefy bars.
It seems almost like a crate staple hit it. However, there was not a puncture in the plastic it was delivered in. Strange.
Is this fixable? If so, is it simply gently blending with some scotchbright and some alodine?
Thanks in advance!
Jason Hess
N777JH - Reserved
RV-7 - Builders Log Tail complete, wings nearly done, starting fuselage!
RV Factory - Complete sans floor coating, Slideshow Here
People are not excellent because they achieve great things; they achieve great things because they choose to be excellent.
Gerald G. Probst, Beloved Grandfather, WWII B-24 Pilot, Successful Businessman
04-20-2012, 12:03 AM
The first thing you do is email this pic to VANs' and then call them during the tech counseling hours.
I made a spar defect during wing tank work. I called them, emailed a pic, and it turned out I was lucky. I polished out the defect, which was outside of a critical zone, and everything is fine.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
04-20-2012, 07:13 AM
+1 on Scott's recommendation.
Rob Prior
04-20-2012, 07:36 AM
Thanks guys, I should have been more clear.
I actually did email Van's last night before asking here. I was hoping to see if anyone else had seen the same or close and what their repair was. A search brought up other areas that had nicks/scratches, but not like this one.
They just replied and said...prime it and build on.
Jason Hess
N777JH - Reserved
04-20-2012, 09:30 AM
stress
I would blend with a scotchbrite to relieve the stress point. If it's more than 10%of thickness I would replace.
04-20-2012, 04:48 PM
More info for VANS
It might help VAN's if you give them more info, Blend the damage first, don't make the blend too tight a radius, measure the length and width of the blend area as well ad the deepest point then give that info to VAN's to assess the damage, from the photo it looks like it might be OK after clean up.
Nick Purcell
Licensed on B767, A330 Eng/Airframe
Fixing up RV6, building a Stewart S51
Basically a major overhaul of everything.
04-20-2012, 05:25 PM
See the Dan Horton posts in this thread.
Dan posted some great diagrams that address this very topic.
Me, I would blend it out to the bottom of the nick and then build on.
Thanks, Bob K.
Bob Kuykendall
HP-24 kit sailplane
EAA Technical Counselor
