Old 04-19-2012, 06:42 PM
912ry 912ry is offline
Default Whats this for?
I have a couple of aluminum bars that are puzzling me. Does anyone know what AB3-5/8x1 1/4x4 are used for?
Old 04-19-2012, 06:47 PM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
According to "The List" it is an F-904E
F-904E AB3-5/8X1 1/4X41.5
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 04-19-2012, 06:56 PM
Default Thanks
Well, you were close but not exactly the part I was looking for. All thoughs numbers can get confusing! But your post helped me find an old thread that had the answer. wedges for the tip up canopy. Thanks for the help!
Old 04-19-2012, 06:59 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default can be used to cut a little wedge...
It can be used to fabricate the little spacer wedge C723 below the canopy strut anchors on each side... I actually made mine from other stock and ended up sending these back with my small pile of returns after the build. I never found any other use for them.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 04-19-2012, 07:05 PM
Default me too
That's what I finally discovered. Made the wedges last year out of other aluminum, found it hard to believe this big of piece is required for the wedge, but now I have something for my next project. Thanks again
Old 04-19-2012, 09:36 PM
Rupester Rupester is offline
Default I have two of 'em ...
...and never have " figgered out" what they're for.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
