Old 04-18-2012, 11:05 PM
aarvig's Avatar
aarvig aarvig is offline
Default Can I safely undo a dimple and then countersink?
The rear wing spar on my RV-9A has doublers that mate with the web and then curl up to mate with the flange. When the skin is riveted on, the aft spar is wedged between the skin and the doubler (in two places). Where the doubler is located on the spar Van's recommends that you countersink the spar and dimple the skin then rivet the countersunk spar between the skin and doubler. I made the mistake of dimpling the spar and the doubler, as a result the doubler doesn't sit flush to the spar flange. Can I use a flat squeezer set and "flatten" the dimple out on the spar and then countersink the flattened dimple, then install a new doubler plate? I guess my question is...is it safe to flatten a dimple and then countersink it?
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 04-18-2012, 11:21 PM
Default pics
Aaron,
Do you have pictures or at least part numbers. I may have done the same thing! I will take a couple pics tomorrow and we can compare.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 04-19-2012, 06:42 AM
aarvig's Avatar
The spar is W907A, the doublers are W907E, W907D and then the top skin.
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
Old 04-19-2012, 06:45 AM
molson309 molson309 is offline
If I understand correctly what you did, it's probably easier at this point to lightly countersink the dimple in the spar until the two dimples nest together. No need to flatten the dimple out to countersink it! In fact the result will most likely be stronger than simple countersinking and certainly stronger than flattening out the dimple first.
Mark Olson
RV-7A First flight 2005 Sold 2019
F1-EVO Rocket First flight 2010
Old 04-19-2012, 07:32 AM
aarvig's Avatar
I tried this. Because of the "over 90 degree" bend in the spar flange and doubler flange it is nearly impossible for me to get the two pieces to nest together flush.
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
