Old 04-18-2012, 04:23 PM
Airzen Airzen is offline
Default Source of RG 142 / RG 400 COAX
Hi All,
Wondering if someone has a recommendation for a place where I can buy RG142 or RG400 Coaxial ables (around 10 foot).
I want to have one with the male BNC connectors already soldred/crimped at both end (that is they can be hooked to the radios and the antenna right out of the box).
Does anyone know of a place who'd make such cable on demand?
Old 04-18-2012, 04:36 PM
s24789 s24789 is offline
Order cable from Aircraft Spruce and two connectors. It will take about 5 minutes to build the cable.
phelps
Kevin Phelps
Paid thru Dec 2020
RV-7A flying N782WP
Stuart, Fl
Old 04-18-2012, 04:45 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Front page advertiser
Second advertiser down on the front page of VAF
http://www.steinair.com/
He sells the supplies to do it yourself and he will also sell you one pre-made I'm sure.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 04-21-2012, 07:30 PM
Flying Scotsman Flying Scotsman is offline
Originally Posted by Airzen View Post
Hi All,
Just a suggestion...learn to crimp the connectors on yourself. Otherwise, you may find that you'll have to have much, much larger openings/grommets in order to feed your cables to your antennae.
It's easy to do...
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 04-21-2012, 08:17 PM
Captain Avgas Captain Avgas is offline
If you buy the cable and connectors (to do it yourself) from Steinair then make sure you get the correct connectors for the RG400 coax. Steinair sent me RG400 cable but sent RG82 connectors which didn't fit properly.
You'll also need to purchase the proper crimping tool (also available from Steinair).
It's best to make your own cables, because as the Scotsman has pointed out it will be virtually impossible to get ready made cable connectors through the wing spar carry through....and if you make it yourself you can lay it our in situ to calculate exactly the correct length. And of course if you have the crimping tool you can always do repairs/modifications.
You’re only as good as your last landing
Bob Barrow
RV7A
Old 04-22-2012, 12:29 AM
Don't forget to design/build in service loops (ask me how I know this).
Santa Clarita, CA
#8,000
