04-18-2012, 10:47 AM
Best cowl heat shield
What's the best heat shield material to use on the inside of the cowling? I'll epoxy it and paint it, then want to put down some of the reflective material...but want to use the best material.
TIA!
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
04-18-2012, 04:11 PM
It's hard to believe
how well plain old aluminum tape from the Home Depot aviation isle works. In addition, it's easy to custom fit whatever area needs covering. I touch mine up at each condition inspection, but it's really only for cosmetic purposes.
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
04-19-2012, 05:17 AM
Local auto-parts store
I use the heat shields sold at the local auto-parts store --- on the -10 and -8A, they have worked great!
04-19-2012, 08:13 AM
I went with the stickybacked, heavy duty aluminum foil stuff Vans carries. Works for me.
Erich
04-20-2012, 04:55 AM
http://www.brownaircraft.com/searchresults.asp?cat=104
this is the real stuff used on certified aircraft. sell what is left over on vaf. they have heat resistent glue also. they can answer any questions you have. do it right the first time.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
04-20-2012, 09:40 AM
This is what Dan Horton suggested I use. FiberFrax 1/16 thick mat from Aircraft Spruce ( http://www.aircraftspruce.com/catalo.../fiberfrax.php
and the put Vans foil over the top. Cut the fiberfrax 2 inches smaller than the foil all the way around so the adhesive on the foil will have something to stick to. I brushed on a coat of epoxy resin all around the edges to seal it up. So far it has worked great. I had an exhaust pipe move and touch the cowl exit on a hour flight and it did no damage to the cowl.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
04-20-2012, 11:58 AM
I used this Cowl Heat Protector from Van's.
To apply it, I used a wall paper seam roller. Here are a couple of pictures:
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
04-20-2012, 06:34 PM
Similar, top quality products can be found here:
heat shield products
The biggest difference between ours and some of the others is ours cost a heckuva lot less!
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
