Nosegear fairing dimple
I am ready to install my nosegear fairing and the instructions mention a dimple that is supposedly molded into the fairing that indicates where to drill a hole to locate the mount for the fairing that is centered and attached with the nosewheel axle bolt.
My fairing has such a small little divit, it looks more like fisheye than an actual dimple. Just want to make sure I am looking at the right spot. It is located 16 3/4" from the aft end of the fairing, which puts it at 5" from the forward edge. Its 4" from the lower edge of the fairing, which may be a bit arbitrary since that is where the initial cutout for the wheel is.
Does this sound like the right spot? I only see it on one side of the fairing as well.....as I recall the right side.
Thanks for the help folks.
Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
