Old 04-17-2012, 08:07 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default Springs fully compressed on Vetterman exhaust?
The instructions that came with my Vetterman exhaust indicate that about three threads should show on the bolts that hold the tailpipes on. However, tightening them up that much pretty much fully compresses the spring. Is that how it's supposed to work?
Am really down to the final (double and triple) checks now!
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 04-17-2012, 10:04 PM
Greg Arehart's Avatar
That's about how mine look. I think you're good to go.
Greg
Greg Arehart
N 7965A
Old 04-19-2012, 07:47 AM
Rupester Rupester is offline
Default Yep, mine too ....
... look about the same. I decided to tighten the nuts to something "reasonable", rather than get all uptight about 3 threads exposed. Seemed to me that having a little compression room in the spring with, say, 2 threads exposed would be just fine.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 04-19-2012, 08:33 AM
aerhed aerhed is offline
Push the tailpipe hard into the ball socket and move it around a little to make sure its fully seated and swage it a tiny bit. Next, tap the flanges a bit with a flat punch. This may close your gap a little bit. Springs that are fully compressed can break from heat expansion. Although in this case, the ears will probably just bend a bit giving more spring relief. Use some nickel anti-seize on the ball joint and the bolt threads for sure. A well hung pipe is a happy pipe.
Actual repeat offender.
Old 04-19-2012, 08:55 AM
Default LOLing here ...
"a well hung pipe is a happy pipe"
That's not the first time I've heard that.
Terry Ruprecht
