Old 04-17-2012, 03:50 PM
NC1572 NC1572 is offline
Default EXP vs Cert engine fly off time
Will the fly-off time of 25 hours using a certified lycoming engine turn into 50 hours if I use an experimental lycoming engine?
Old 04-17-2012, 03:58 PM
Mel's Avatar
Mel Mel is offline
Phase I flight test time is a minimum of 25 hours if a certificated engine/propeller combination is used. That means no modifications at all to the engine such as aftermarket ignition and/or fuel injection system.
Otherwise, it will be a minimum of 40 hours phase I time.
Remember these are minimum numbers. The inspector can add hours for anything that makes him/her uncomfortable.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
