Hi,
I have a TruTrak ADI with internal GPS, I'm trying to disconnect the GPS antenna. I believe the plug is an SMB connector which is a push on. I have been pulling at it but it doesn't want to come off
As the case is plastic I don't want to pull too hard. Does anyone have experience of disconnecting these plugs? How hard should I pull - its difficult to get a good grip? is it necessary to use pliers? The connector spins but doesn't unscrew, so isn't corroded.
Thanks, Pete
