Old 04-16-2012, 05:59 PM
SmittysRV's Avatar
SmittysRV SmittysRV is offline
Default Short Pigtail Ground Wire D-100
I'm wiring up the Dynon D-100 in my RV-9A panel using the wiring harness and there is a short black and white wire that was labeled "Pigtail ground for shielded braid". I know that the #19 pin wire from the GTX327 Transponder is supposed to connect with the #13 pin wire on the Dynon D-100, but what about the ground shield around the #13 pin wire? What does it connect to? Does it connect to that short Pigtail ground wire? Any help would be greatly appreciated.
Smitty
Old 04-16-2012, 08:28 PM
TX7A TX7A is offline
Smitty,
This sounds real familiar to me. Seems I've been through this. I think the short wire is for an encoder if you require one. Take a look at page 3-8 here: http://dynonavionics.com/downloads/I...tion_Guide.pdf
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 04-17-2012, 12:52 PM
SmittysRV's Avatar
The description of the wiring harness on their website mentions the pigtail, but the written instructions do not. I downloaded the document and did a scan and it doesn't mention "pigtail" anywhere. Dang..
http://www.dynonavionics.com/docs/D1...ISHarness.html
Smitty
Old 04-17-2012, 12:58 PM
Brantel's Avatar
Brantel Brantel is offline
It is simply the ground wire for the shield. Ground it to your common ground point and all will be well.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
