Old 04-16-2012, 09:22 AM
Daniel S. Daniel S. is offline
Default Opps Rivets
Hey all-
Does anyone know of a place that has "oops" rivets in stock. I can't seem to find them anywhere. What a pain for a single rivet!
Thanks.
DANIEL S.
RV7-A (528KS)
-Empannage Done.
-Electrical System Planning / Schematic Done.
-Wing Kit Delivered 09/13/12.
-Wings 95% Done Flaps & Electrical to go.
-Have got to order the fuse soon!!!!.
[/font]http://www.mykitlog.com/dschoning/
"This is a first-time event, and we're looking forward to it"... Chuck Yeager
Old 04-16-2012, 09:31 AM
ppilotmike's Avatar
Default Opps rivets...?
Not sure what Opps rivets are, but you can order "Oops" rivets in Vans webstore, with quantities as low as 0.01 lbs, which isn't too many. They will likely send them in an envelope too, so shipping isn't much. I ordered 0.01 of several sizes early on so I'd have them throughout the build.
Mike Rettig
VAF Dues Current
Old 04-16-2012, 10:08 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Spruce has them -
http://www.aircraftspruce.com/catalo...izerivets2.php
They will sell 1/8 lb. for the princely sum of $3 to $4 - Buy a bunch and share them with the other RV builders in your area...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-16-2012, 12:54 PM
N9331v's Avatar
N9331v N9331v is offline
What size you need ????
I have some extra -3.5 and -4 oversized
I can throw some in the mail for ya.
Ed Martin
Bluskydtl
RV7
DKB
Donations 1/19 & 6/19
Old 04-16-2012, 12:57 PM
vlittle's Avatar
vlittle vlittle is offline
The AD3 size rivets are available from:
Pegasus Auto
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 04-16-2012, 01:08 PM
beav's Avatar
beav beav is offline
Van's stocks both the AD3 and AD4 sizes in several lengths with prices that are much lower than Pegasus. You used to have to ask for the AD3 rivets, but they're listed on the store now.
jason
jason
N4VR
RV-7 (Flying)
http://www.jasonbeaver.com/rv7
Old 04-16-2012, 03:43 PM
bird's Avatar
bird bird is offline
Default VANS
Van's has them all that you would need.
bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 04-16-2012, 05:06 PM
QueueCT QueueCT is offline
Per Gil above they are NAS1097 AD4-xx rivets and are in stock at Aircraft Spruce. I have a handful of different lengths and they came in handy when I was learning how to drill out rivets. Sometimes the hole got a bit too big and had to be enlarged to take a 1/8" shank but still keep the 3/32 head for the existing dimple.
John Qudeen
RV-9A Fuselage (ready to roll the canoe)
N211EG (reserved)
Old 04-16-2012, 05:10 PM
bkthomps bkthomps is offline
your best bet in my opinion is to buy this and have it on hand:
http://www.averytools.com/prodinfo.asp?number=1097K
You will probably need other less common ones, try local builders before you order up a whole batch
Old 04-16-2012, 05:47 PM
Andrew M's Avatar
Andrew M Andrew M is offline
Default which one?
NAS1241AD rivets are 1/64 oversize (1242 for universal head) NAS1097 are next size up with reduced head(#4 rivet with a #3 head) Why blow open a hole the full next size when someimes you can go half way?
Genuine has both.
Andrew Miller
A&P, IA
-9 empennage
Wings arrived 12 JAN 13
https://plus.google.com/photos/11360...J-TuJPsmOONzQE
