Old 04-12-2012, 09:46 PM
RidiculousM RidiculousM is offline
Default Flaring tool, which one?
Any recommendation on which one to get from Aircraft Sruce?
Mike
Old 04-13-2012, 03:26 AM
mikehoover's Avatar
mikehoover mikehoover is offline
I have the Parker Rolo Flare and have been very pleased with it.
http://www.aircraftspruce.com/catalo...ringtools2.php
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 04-13-2012, 05:34 AM
I have a RFT37 from GAHCO---is wonderful.
Tom
Ridgeland, SC
Old 04-13-2012, 05:38 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
Parker Rolo Flare!!!
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 04-13-2012, 05:40 AM
blueflyer's Avatar
blueflyer blueflyer is offline
Default Parker Rolo
Parker Rolo. Its expensive, but its worth it.
Old 04-13-2012, 09:16 AM
Rick_A's Avatar
Rick_A Rick_A is offline
The Parker ROL-AIR is a few dollars more and also works very well. The ROLO Flare is certainly the most common but I found the 2 piece ROL-AIR made it a little easier to get in to some tight spots.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 04-13-2012, 10:00 AM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
Ditto Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
Old 04-13-2012, 10:59 AM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
The problem with your common Rolo-Flair Tool is it's quite difficult to make a flair when the bend is near the flaired end. If you flair first, maybe you can't make the bend close enough. If you bend first, the RFT requires too much straight tube to make the flair.
Ralph Finch
RV-9A QB-SA
Davis, CA
Old 04-13-2012, 05:16 PM
Capflyer's Avatar
Capflyer Capflyer is offline
Since I have the Rol-Air I'll of course say it's the best
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
