04-12-2012, 08:10 PM
Hartzell CS BA vs Composite vs WW200RV- Help Please
I am in need of data, please. My order of the engine and prop is pending a decision. I am building an RV7 with IO360 ( standard compression) and Sam James cowl. Here is what I can find here on VAF for weight: Hartzell BA - 58#, Hartzell Composite - 42#, WW200RV - 40#, Sabre 2.25" extension ~5#.
I am not looking for an "aerobatic" prop ( thanks for the information Smokey), but still desire to do mild aero ( loop, roll etc). Also, highly desiring good cruise performance with the BA as a baseline. I can not find a single individual that has posted data from a Hartzell composite - at least for an RV. 6 hours of searching and reading!
I did see flight test data (processed) showing the 76" Hartzell composite better than the BA, on a 3000 # plane. I think it was 7497 vs 7605.
The fine people at Hartzell offered to provide some comparative analytical information of BA vs Composite (thanks John P) but I am still looking for some real data.
I understand that the BA+2.25 spacer is considered OK, for ~+4G, but not sure if any agreed benefits would be provided by the composites.
The lighter weight seems like an advantage, but not for a loss in performance. It seems the 200RV has comparable performance to the BA, but the Hartzell composite?
The Hartzell has 2000 hr TBO, the WW, 650 hr (not 500) inspection. + for the Hartzell.
If i have the numbers wrong, correct it please, and 3 blade consideration is out.
So what are others using with SJ long cowls and 180 hp?
Thanks ,
Bill
RV-7
Lord Kelvin:
Reason: incorrect information
04-13-2012, 04:44 AM
Bill,
The WW 200RV inspection interval is 650 hours.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
04-14-2012, 08:57 PM
Another Option...
Bil,
The SJ cowl's down side (and HR2 for that matter) is the (heavy) extended hub required for a C/S prop. Having been there, done that I can throw in option three for the SJ cowl. Having flown built and inspected alot of RV's, I still like FP Catto composite props for overall economy and performance. You also avoid the extra cost, maintenance and nose weight of all three above options.
Pictured below is Chad J's former RV7 with Manual Flaps, MGL Enigma, O-360, cold air induction, Sam James everything and a Catto 3 blade. Having flown many 7's, Chads was the fastest, lightest and most fun to fly of all. He sold it to a customer of mine in S. Africa who loves it.
If I were building a Seven with a SJ cowl...I know how I would choose
V/R
Smokyray@rocketmail.com
04-14-2012, 09:27 PM
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
C/S prop
I now have the Hartzel BA.
The Catto will be my next prop on the -7.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
04-14-2012, 09:38 PM
It's no secret which prop I think is the best. WW200RV comes with a fitted carbon spinner weighs under 40#. Seems to be as fast at 2600rpm as the Hartzell is at 2700. And isn't too bad to look at either....ok I may be bias
Straight and level 190Kts TAS. I've seen 193, but hard to snap a cell phone pic when wringing it out and looking for birds.
04-14-2012, 09:51 PM
I have the Hartzell BA
prop on my 7A Slider. Standard Van's cowl with Superior 360 180hp engine. I'm admittedly heavy with MT weight of 1200lbs due to two 680 batteries on the firewall, extra firewall insulation, redundant IFR panel and and a beautiful Classic Aero interior. I'm nose heavy having to watch the max 375 lb. nose-wheel weight with just me in the seat and nothing in baggage.
Knowing what I know now, my first choice would be the composite Hartzell, but I'd also be looking at the Cato if $$ was a big deal. Love that short takeoff and landing provided by the constant speed prop. though...
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
04-16-2012, 09:56 AM
If you go with a lighter weight prop, think about CG. I didn't.
I love my WW200rv, though I don't have any performance data. However I am limited on baggage weight if carrying a passenger.
Zero fuel, 360lbs of meat and 55lb of vegetables puts me right on the aft limit.
IO360, WW200rv. Battery on FW.
Dynon servos, Whelen strobe unit and ELT behind baggage.
Painted but no gear leg or wheel fairings yet.
Empty wt. 1055lbs
A longer engine mount would be the ideal solution.
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
04-16-2012, 11:57 AM
Catto
Save the money and purchase a Catto 3 blade. I have had a Blended air foil on a 8 and also a Catto 3 blade on a 8, I liked the Catto better. I just ordered a 3 blade for my RV-3B the other day.
David Herrmann
RV-7 N174DH built and sold
RV-8A N369DP purchased and flying/ Sold
RV-8 N3170L purchased and flying/ Sold
RV-3B N313RV purchased and flying Sold
RV-4 N488TW Flying  Sold
1946 J3Cub all stock and original flying Sold
1943 Meyers OTW-160  sold
1997 RV-4.5 N221TM wow, sold
04-18-2012, 05:07 PM
Thanks to all who have posted information here. I continue to talk with the two propellor guys ( WW and Hartzell) and am not sure a bad decision can be made between the two, given that the result is a constant speed prop.
Basically it seems that the efficiency, and speed of the Hartzell BA and composite, and 200RV are just about equal. I mean to the third decimal. It seems that the BA is better at higher altitudes, but the composite is excellent for TO and Climb. The WW vs BA, is well compared by Mr. Vetterman's data.
Thanks for the heads up on the weight and balance, not sure how to engage definitively with that, but forewarned is forearmed . . .
I will continue to dig for a few more days, then decide in time for the SnF discounts to apply.
Bill
RV-7
Lord Kelvin:
05-08-2014, 10:43 AM
Hi Bill,
Curious what your final decision was and how it worked out?
AP/IA/CFI/ATP/EAA TC
RV-7 Tip N77XA
Paid 11/15
