View Poll Results: Technical Counselor and or A&P with IA
Technical Counselor
11 |
31.43% |
A & P with IA
0 |
0% |
Both
24 |
68.57% |
04-12-2012, 12:18 PM
Technical Counselor or A&P
Just wanted to get a few thoughts from everyone. I am slow building an 7A and I have an A&P with IA to look over my work when I get far enough along. I know some use the EAA Technical Counselors to do the same. Do any of you have any opinions on which they prefer or both.
04-12-2012, 12:25 PM
Both, for me. As many eyeballs as possible.
All Best
Jeremy Constant
When I start my build, I'm going to have as many eyes on it as possible. Evaluate each concern separately. If it has merit, who cares where it came from.
Every eye you can get on it is a good one. Even the untrained eye can find things for discussion.
Once you find a real problem that needs discussed or resolved, you're the tie breaker between all the resources you can find. A&P/IA, Tech Counselor, Manufacturer, and peer builders.
But I'm of the opinion that any critical eye is worth taking advantage of.
Phil
04-12-2012, 12:35 PM
I know some IA's that couldn't drive a rivet if it were to save their soul. I even know a few that I wouldn't let work on anything that flies and tell people to steer clear. Last year I worked on a Champ that had a fuel hose literally made from braided line you would use for a washing machine (not kidding.) And it passed annual for years. There are plenty of RV builders around that know aircraft construction much better than do many mechanics. Not to say there aren't any good A&P/IA's around. There are.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
04-12-2012, 12:37 PM
Regardless of their "qualifications" find someone you trust that know's RV's. I have met a lot of "marginal" AP/IA's, and some very good ones.
As others mentioned, more eyes the better.
Mine was "inspected" by several Van's employee's, a Tech Counselor, DAR, AP/AI, prior builders, and probably another dozen or so people through various stages of the build.
One advantage of being in the "Home Wing" area.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
04-12-2012, 12:53 PM
We had an A&P, and an IA, and a Tech Counselor, another dozen or so people through various stages of the build inspect our 9A.
Phase one squawks:
Adjust one line routing...
Nothing beats and extensive review process to eliminate issues before flight.
Dave & Trina
RV-9A Flying  - 330 Hrs. Painted  Finishing the interior.
04-12-2012, 01:05 PM
The fancy titles and letters mean next to nothing. Get someone who has built an RV or two, and you have a much better source of knowledge. Many with the titles have never seen a homebuilt.
04-12-2012, 01:38 PM
Maintenance vs manufactue
Each profession has something a little different to bring to the table, as each individual will have a different skill set and knowledge base. Building has it's own issues different from maintenance. More different kinds of eyes is something to take advantage of. Although my job description is to maintain an entire aircraft, there are times when as a lead I get the right guy for the job. A really good mechanic, builder, or owner will recognize something unfamiliar and call in more brain power.
04-12-2012, 01:57 PM
This.
Nothing beats direct hands-on experience with the RV's. Our local airport community has built half a dozen RVs over the past 12 years I've been hanging out there, and every one built has been gone over with a fine-tooth comb by at least different ten sets of eyes before it ever flew.
Neal Howard
Airplaneless once again...
