Hi Jay,
it should work but be aware that, because of the removed material, countersunk rivet spots are not as strong as dimpled ones. to dimple the rib and to countersink the ring for standard rivets, like the manual is telling you, is an easy and straightforward way to attach the two pieces together. i don't see any reason to deviate from the plans here, so i'd like to recommend to stick to the manual.
Kay Stecklum
RV-7 wrap-up/Electrical
