Originally Posted by Ron Lee
Apparently the SARSAT system picks up plenty of maintenance/testing ELT signals. The testing of 406 MHz ELTs is reportedly different than the top of the hour five minute window I recall for 121.5 MHz units.
Ideally someone with a 406 MHz ELT can read the manual and post the testing procedure here. IF you have someone doing an annual/condition inspection, advise them of proper testing procedures...
From the ACK E-04 manual:
"During the self test, the ELT transmits on 121.5 Mhz for 1 second, (3 audio sweeps) then transmits a 406 Mhz test burst for 550 ms then returns to the armed mode."
"You must perform a self test (with the remote panel self test button) every three months to verify the ELT is functioning properly."
There is no mention of when to do the test. Since satellites are no longer monitoring 121.5, perhaps it doesn't matter when the test is done if you are not in a place where ATC can hear 121.5? Or maybe a 1 second burst won't worry anyone? I have wondered about this myself as the mandatory self test is considerably less convenient if it is necessary to do it in the old 5 minute time window every hour.
For the annual test which includes the G switch test, the manual does say to do it between the hour and 5 minutes after, "as per FCC requirements." There is an additional note for the G switch test. "As soon as you hear the tone immediately turn the main switch on the ELT to the Off position. The ELT when activated transmits on 121.5 Mhz for approximately 50 seconds before a 406 Mhz burst is sent to the satellites. This is a live burst which will immediately notify the COSPAS/SARSAT system that there is an emergency.
It is imperative that you do not allow an activated ELT to transmit for more than 30 seconds during G switch testing"
