04-10-2012, 04:40 PM
Jumper wire for #1 terminal ACS switch
Finishing up wiring and doing ign switch. I have only one impulse coupling and that's on the left mag (normal
Diagram says add jumper between/connecting the two side by side posts for the right mag wire.
The question is pretty basic: Do you all just use a basic 18 ga. wire with eyes on each end?
Sandy Toomer
Commercial, Instrument, A&P
EAA: 1023750
Based Lanett, AL (7A3)
Auburn, AL
WAR EAGLE!
04-10-2012, 05:22 PM
Should be a jumper already installed on the ignition switch, if its a new one.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
04-10-2012, 06:45 PM
The acs switch is supplied with a metal tab for jumper if you do'nt have it 20 guage wire is plenty big
Jerry Scott
Rocket II
04-28-2012, 12:30 PM
We didn't have a wire with the switch so made one up from 18 ga and done.
Sandy Toomer
EAA: 1023750
Auburn, AL
WAR EAGLE!
04-28-2012, 03:57 PM
Not trying to be nick picky but your crimper does not look like it's doing a very good job (at least on the insulation).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
04-29-2012, 07:47 AM
Should have had a jumper with the ACS switch. It resembles a bicycle chain master link.
04-29-2012, 10:29 AM
Takes about 30 seconds to nip out a piece of metal with snips and drill 2 #19 holes.
Actual repeat offender.
