04-06-2012, 10:48 AM
Huge bulge in wing rear spar of an RV-8
Hello Together!
In the last time I have a real streak of bad luck?
By the installation of the gap filler of the wing, I made a huge bulge in
the rear spar of the wing. (See pictures) What shall I do now? I know the
rivet is to flat, too, but drilling it out could make everything even
worse?
Thanks for your help!
Best wishes,
Anna
04-06-2012, 11:09 AM
Senior Curmudgeon
Looks like you need to lighten up on your riveting.
What pressure are you running to the gun??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
04-06-2012, 11:12 AM
It will be just fine.
You can do nothing and no one will know but you.
Originally Posted by Anna
What shall I do now? Thanks for your help!
Best wishes,
Anna
Kahuna
6A, S8 ,
Gold Hill, NC25
04-06-2012, 11:28 AM
Second that
Your best fix is to leave it alone.
EAA Technical Counselor #5357
04-06-2012, 05:06 PM
Not too bad
I would remove the rivet and flatten the bulge using wooden blocks (hardwood) and a hammer. You may need a helper to hold the blocks. If you remove the rivet carefully you shouldn't damage the hole. Then set another rivet. Possibly practice on some scrap first.
If this is the worst thing that happens when building consider yourself fortunate.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero- HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
04-06-2012, 05:07 PM
If it was me, I'd probably remove the rivet for inspection, gently "tap" the area to make it flatter and then re-install the rivet. The head of the rivet is so mashed that any tension on it would likely shear it off anyway (I know it "probably" loaded in shear). I would also send the pics to Van's engineering just to get their blessing, after all we are talking about the rear spar here. Damage to the spars should not be taken lightly.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
