Old 04-05-2012, 05:18 PM
TThurston TThurston is offline
Default Wrong dimple for CS4-4 Pop Rivets
I just discovered that CS4-4 pop rivets use a different dimple than AN426 rivets. I've almost finished my tail, and so far I used a dimple die for AN426 rivets for all the CS4-4 pop rivets I've used so far. I noticed that rivets were not quite flush like the AN426 rivets, but assumed that was just how pop rivets were.
How bad is this? Any suggestions?
Finishing -12 tail cone
-9A Empennage done, in storage
Old 04-05-2012, 06:29 PM
bhester's Avatar
bhester bhester is offline
Red face Your not alone
I did the same thing on two of them on each side. They are just going to set a little high. No problem.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 04-05-2012, 07:57 PM
bcondrey bcondrey is offline
Angle is different on the CS4s but a lot of folks use the 100 degree dies and live with them sitting a little proud. Cleaveland and others sell a 120 degree die set for them and they will sit flush if those are used.
Bob
