Old 04-05-2012, 03:48 PM
APACHE 56 APACHE 56 is offline
Default IPad spot report
I have a new iPad 3 - wifi only - 16G. I flew with it in bright FL sun from 1000 hrs to 1200 hrs over Central Fl (Cocoa Beach area). My aircraft is a RV8 with a Todd max tint canopy. I don't have my pad fixed to the airframe. Rather I use it like a paper map and keep it stuck in a side pocket or a footwell when not in use. There was no issue with seeing the screen clearly. Yes if you hold it just right you can get a specular reflection but you can do that with a ham sandwich also. I am most pleased with the iPad performance when using it in a gps referenced moving map mode.
Don
Don Stiver
RV8 "Little Pill" N6371S, Merritt Island, Fl.
BPE IO-390, Dual P-mag, MT 3-blade, AFP system
Steen Skybolt: Sold
Old 04-05-2012, 03:57 PM
bret's Avatar
bret bret is offline
I have the same one and love it, waiting for the fix for WINGX.
Old 04-05-2012, 06:19 PM
BHunt BHunt is offline
Does the wifi only iPad 3 have a built in gps?
Old 04-05-2012, 06:34 PM
Snowflake's Avatar
@BHunt: no, it does not. It does work well with Bluetooth GPS's though.
Rob Prior
Old 04-05-2012, 07:37 PM
Default No on the internal gps
Only the 3g/4g units have the built in gps but my wifi only unit has a feature that when connected to the net allows it to locate itself. Of no utility to aviation however.
I haven't paid any attention to it because I wanted a remote antenna and chose the DUAL (red dot) system (~$99). The reason is that I don't want to have to keep the iPad in a position enabling it to see the satellites. As I said I like to stuff it out of the way when I?m not using it.
Don
Don Stiver
Steen Skybolt: Sold
Old 04-05-2012, 10:10 PM
What are good Bluetooth gps's?
Old 04-06-2012, 04:00 AM
Default bluetooth gps
I am aware of two: Bad Elf and DUAL. I bought the DUAL based on a demo flight using the system. Everything about it (and the iPad) is easy. That is, easy to set up; easy to use.
Don
Don Stiver
Steen Skybolt: Sold
Old 04-06-2012, 05:10 AM
Kevin Horton's Avatar
Don
The Bad Elf GPS does not use Bluetooth. It must be physcially plugged into the port on the bottom of the iOS device. I've got one, but never liked the somewhat flimsy USB connector on the Bad ELF, as you need to plug into that if you want to power the iOS device while using the Bad ELF GPS.
I bought a Dual Bluetooth GPS at SNF, and like it much, much better than my Bad ELF.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 04-06-2012, 05:44 AM
Tom Martin Tom Martin is offline
On my recent trip to Sun N Fun the built in gps on my new Ipad III worked much better then that of my original Ipad I. It seems to capture the signal faster and never lost the signal as the older version did occasionally. I have the unit strapped to my leg and use it for flight planning, current charts, maps etc. It is not, nor will be, my primary gps unit, but based on that flight experience I can see no need to have an external antennae.
It does generate more heat then the original and although the sunlight readability is not perfect it is an improvement over the first Ipad.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 04-06-2012, 09:20 AM
sailvi767 sailvi767 is offline
My wife recently bought me a Ipad3. I think the fact I was using her Ipad2 in the aircraft convinced her to get me one of my own. The difference in the screen brightness is marginal at best. I have compared them side by side. The 3 is still difficult for me to see in bright sunlight. I have mine mounted on the instrument panel right side using a ram mount. In general I have noticed that those that have them on their legs or lower in the cockpit are happier with the screen issue. The ability to move the unit to effect viewing angle or get it shaded makes a big difference. I still like having it in the aircraft but the new model did not do much to fix the the issue of screen brightness in direct sunlight.
Now does anyone know if there is a way to have the map presentation in foreflight oriented to track up rather then N up?
George
