Old 04-05-2012, 02:57 PM
kjelle69's Avatar
kjelle69 kjelle69 is offline
Default Imperial Three way Fuel valve Maintenance.
Anyone who has a good description of how to properly service an Imperial Fuel valve. Lubrication, check points, wear determination and general suggestions?
________________________________________
RV-4. O-360A1D/180 with Pacesetter 200 Prop.
Old 04-05-2012, 04:08 PM
Kent Ashton Kent Ashton is offline
Do you mean the infamous "John Denver killer" Imperial valve?
http://www.avweb.com/other/ntsb9905.html
Lube it lightly with a product called "Fuel Lube".
http://www.aircraftspruce.com/catalo...ezturnlube.php
Use just a light coating on the spool. If you use any excess, it will get into your gascolator screen and avgas does not dissolve it. The valve should not kill you if you maintain it properly. RIP J.D.
