Old 04-04-2012, 05:01 PM
whittfic's Avatar
whittfic whittfic is offline
Default Heater box question
I am thinking about using the DL-01SS heater box for my RV6 and have a question about the actuating cable. The way I am looking at it this (and other units I have looked at) seem to operate by pushing the cable knob in to allow warmed air to flow into the cockpit. This would mean that the knob is extended out from the instrument panel when heat is not required. This seems a little counter intuative. It seems more natural to me to want to pull the heater knob for heat and push in to close it off.
I know we all walk around upside down here in the southern hemisphere so maybe I am thinking about this the wrong way around, but I am interested to know what others have done or if I am missing something here.
Clive Whittfield
Auckland
New Zealand
Old 04-04-2012, 05:34 PM
Save your money and get one of these units:
http://www.aircraftspruce.com/catalo...terbypass2.php
They operate like Vans TG-10 but are all stainless steel.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 04-04-2012, 07:03 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Cable connection direction
Not sure of the operation of the unit you have in mind, but how it operates is a matter of how the cable "approaches" the box. In my case, the box "opens" for hot air when the lever is rotated down. Therefore, my bowden cable approached from the bottom, so when you pull the knob out it pulls down on the lever opening it for heat flow.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 04-04-2012, 08:34 PM
Rupester Rupester is offline
Default I have the stainless steel one ...
... mentioned above. The damperr operating arm is inside the cabin so the cable need not penetrate the firewall. The knob is IN when the damper is closed. You pull the knob OUT to get heat.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 04-05-2012, 12:54 PM
whittfic's Avatar
Ever have one of those 'Duh' moments? I did shortly after I pushed the submit reply button of my original post. Don you are right of course, it depends on which direction the cable approaches the box. Kicking myself for not seeing the obvious.
And the stainless steel version of the TG-10 Colin mentioned will do the job nicely.
Many thanks folks.
Clive
