Old 04-01-2012, 08:58 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default anti-seize/spark plug question
Am about ready to start it up. Not sure if I will get all the way to it today, but am hopeful. A very basic question...
Yesterday I drained preservative oil out of the bottom plugs. When I install the spark plugs (with some anti-seize on the plug threads), do the spark plug holes in the cylinders need to be clean and dry for the anti-seize to do its job, or is a little bit of residual oil on the threads OK?
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 04-01-2012, 09:17 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Congrats!!!!!!!!!!!!
Good for you.
I did not clean the plug threads, just used a bit of antiseize when I did my first plug installation prior to startup.
I have not had any issues with doing it that way.
Right or wrong, it worked for me.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-01-2012, 10:13 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
Everything you ever wanted to know about spark plugs here...
http://www.championaerospace.com/***...-R-Nov2004.pdf
I couldn't find a reference to cleaning the spark plug hole from oil, but did notice cleaning the wire connector end was required.
It's a long, good read.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-01-2012, 12:25 PM
Thanks for the replies. Gil-can always count on you to dig up manuals that I didn't know existed.
Although I'm using Unison spark plugs, rather than Champion, I was able to find the equivalent manual. http://unisonpubs.com/docs/F-1100-L-1710A.pdf
The Champion manual is still useful, however, b/c it has a lot of good pictures with description.
Thanks again.
Steve M.
Ellensburg WA
Old 04-01-2012, 11:09 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Probably a good move too!
I have been involved in a private informal survey of Beech owners and the folk at GAMI.
We have found Champions resistor values drift in time. Some very short amounts of time.
My suggestion is every 50 hours, clean and gap, and check resistance. The resistance should be around 1300-1500 ohms. Any at or close to 5K or more.....BIN THEM.
I have worked my way through about 24 champs now in 560 hours, we had a Tempest set and they are rock stable.
Your Maggies will appreciate it too I think!
